The Mitutoyo Surftest SJ-210- Series 178-Portable Surface Roughness Tester offers a 2.4-inch color graphic LCD for excellent readability, is easy to operate and contains an alarm that warns you when the cumulative measurement distance exceeds a preset limit.
